automatic dimension tool Settins
Discussion in 'Flexi' started by Yammaski, Sep 30, 2010.
  1. Yammaski
    Yammaski New Member
    6
    Sep 30, 2010
    mol
    Is it possible to set a default for the "automatic dimension tool" ?
    I can change the fonttype and height, but the next time I want to use it, it changes back to the FlexiSign settings ... to big for me.
    FlexiSign 8 Pro
    Yam.
    [​IMG]
  2. cgsigns_jamie
    cgsigns_jamie Very Active Member
    Select the "Vertical Dimension" -or- "Horizontal Dimension" tool in the tool bar.
    Then in Design Central change all your settings to what you'd like.
    Then click the "Arrow" (Select Tool) button in the tool bar.
    This will change the defaults for the Dimension tool.
  3. Yammaski
    Yammaski New Member
    6
    Sep 30, 2010
    mol
    Thanks Jamie !
