Automotive Base/Clear on Wood
Discussion in 'General Signmaking Topics' started by rjssigns, Jun 11, 2020.
  1. rjssigns
    rjssigns Major Contributor
    5,164
    521
    113
    Jun 4, 2007
    Home Office
    I tried the search and didn't find anything relating to automotive finishes on wood. Tried a Google search and instead of help those forums devolve into opinions/bickering.
    Since it's for a yacht client spec is a base/clear finish. While I've gotten base/clear on wood stands that hold up motorcycle parts(and it looks great) I've never done it on purpose.
    My thought is to use 2K style primer, wet sand to level, shoot base, apply logo, 3 coats of clear then cut and buff. Logo/lettering will be Real Gold with Edge printed stroke.
    Anyone see anything wrong with the process?
  2. Notarealsignguy
    Notarealsignguy Active Member
    966
    250
    63
    Feb 20, 2020
    Florida
    Are you trying to get it smooth? I did a project and painted cabinets and plywood accents in base clear. Used an epoxy primer first, then body filler on the edges (dont put body filler over raw wood), then slick sand, sanded that, hit with some 2 part putty as needed. slick sand again, sand again. Then base/clear.
  3. rjssigns
    5,164
    521
    113
    Jun 4, 2007
    Home Office
    Thank you for the information and client wants it perfectly smooth. Sounds like I'm headed in the right direction anyway.
    What epoxy primer? I think I've got some leftover DP50 in the shop.(may be expired though, same with my 2K)
  4. Notarealsignguy
    966
    250
    63
    Feb 20, 2020
    Florida
    Its been awhile, was either axalta or this high build marine epoxy we use. It is similar to sherwin williams macropoxy. Any should do, its just to seal up the wood. It’s a fair amount of work. A urethane surfacing primer will work in place of slick sand if you cand find it.
  5. rjssigns
    5,164
    521
    113
    Jun 4, 2007
    Home Office
    Cool. I'll check into the products you suggested. My big thing is getting the wood completely sealed.
  6. Johnny Best
    Johnny Best Very Active Member
    3,417
    1,909
    113
    Dec 9, 2015
    buffalo ny
    West System epoxy ( not sure on numbers, 105 resin and 207 hardener, if I remember right ) with one good prep and coat, sand, and then around 3 or 4 coats of marine varnish, Pettit marine UV inhibiters varnish. Or finish with clear two part AwlGrip instead of varnish.
  7. rjssigns
    5,164
    521
    113
    Jun 4, 2007
    Home Office
    Thanks for the information. It may come in handy with the type of work I do. Going to run with an automotive type finish system since that's in my wheelhouse.
