backlit material with removable adhesive?
petepaz
quoting a job for some backlit panels but customer wants them on the outside of the glass with removable adhesive.
so far only materials i can find have a perm adhesive. any ideas?
i was thinking of just printing on clear with removable but not sure i can get a good enough print for the backlit.
J Hill Designs
can you laminate printed translucent to removable clear?
klmiller611
I just got samples of some material from Drytac that is a translucent material with removable adhesive. There is a piece of it on my office glass right now. Easy to apply, easy to remove, has both a white version and a matte finish. It is called "Spot-On".
http://www.drytac.com/spot-on.html
The adhesive makes it easily repositioned. YAMMV!
Best
Ken
petepaz
thanks for the info. i will check out the drytac material.
i thought about mounting a perm material to the clear removable saving that as a last resort because of cost and the panels are 3ft by 8ft so don't want to risk screwing up the print/material during the lamination
