Backlit printing passes on Epson S60600
Discussion in 'Materials' started by Rachel Bigelow, Oct 2, 2020.
  1. Rachel Bigelow
    Rachel Bigelow New Member
    21
    2
    3
    Feb 10, 2020
    Troy, Mi
    New to creating profiles on an Epson, but is there a way to change the amount of passes on a generic backlit profile. We have a job that only has black lines that need to be printed and I need something faster than a 12 pass profile.
  2. unclebun
    unclebun Very Active Member
    I guess I'll ask the obvious question that if you're doing a backlit sign which only has black lines on it, why are you printing it rather than cutting it from black vinyl?
  3. balstestrat
    balstestrat Member
    357
    43
    28
    Aug 25, 2020
    Europe
    Easier?
    But OP why don't you just use a non-backlit profile then if you need it faster=less ink...?
  4. ExpertWideformat
    ExpertWideformat New Member
    11
    3
    3
    Aug 22, 2020
    Colorado
    This may not be much faster, but it’s my favorite setting for good backlit printing-
    Use your standard 8 pass vinyl profile (I like ij180 or ij35), BUT create a Custom Media setting that has a multi-strike of 2 (double-strike).
    This can be done from the Epson Edge Dashboard or directly from the printer’s front panel.
    Go into Menu > Media Setup > Customize Settings > find an open slot > name it > look for Multi-Strike Printing > set it to 2 (generally speaking, anything over 2 is overkill)
    So, from the RIP you’ll be selecting 8 pass ij35 (or whatever your normal vinyl setting is). By selecting the new custom media the printer will double up the ink in an extra pass. Which equates to roughly a 16 pass. The benefit is you’re getting 2 layers of less ink. So the color doesn’t get too dark, but you’re still getting good saturation. This equates to more even day/night backlits. ‘ Looks more natural (not too dark) when it’s not lit during the day, but looks rich and saturated when lit at night.
    In the case of black only, you can probably get away with a using a standard 8 (or 6) pass vinyl profile. No need for the multi-strike. Just use a rich black of a cmyk of something like 100/100/100/100. The rip will back that off but it will remain a pretty heavy composite black.
  5. Rachel Bigelow
    21
    2
    3
    Feb 10, 2020
    Troy, Mi
    They are being printed to use as templates to drill on car parts. So it's not being put on a backlit sign .
  6. balstestrat
    balstestrat Member
    357
    43
    28
    Aug 25, 2020
    Europe
    Is the part then backlit or why do you even use a backlit profile to begin with? Why not just use a normal profile?
