Backup power supply
Discussion in 'Digital Printing' started by DGDesigns, Nov 5, 2009.
  1. DGDesigns
    DGDesigns Member
    96
    Any suggestions on temporary backup power supplies for a digital printer??
    I am looking for a unit to support a Roland SP540i which uses 7.6amps and 1030watts.
  2. ProWraps
    ProWraps Very Active Member
    3,556
    Sep 30, 2009
    San Francisco, CA
    we bought 4 pretty large ones. two for our printers, two for our computers. the printers drew too much power and we had to take them back.
    i think you have to have a very large one unfortunately. they just tripped the alarms on them from the get go. let me know what you find that works for a reasonable price. i would still like to have two more for the printers.
  3. cgsigns_jamie
    cgsigns_jamie Very Active Member
  4. ProWraps
    3,556
    Sep 30, 2009
    San Francisco, CA
    you are right on the money. and not talking about one of those surge protector sizes. even the mid range stand alones arent large enough.
  5. cgsigns_jamie
    I have the same one for our server. That'll run for about 2 hours on the battery ... the printer, however, draws a bit more power and would only run for about 7 minutes. I'd like to buy a bigger one but need to save a bit more $$$
    They aren't cheap but they are worth every penny!
  6. ProWraps
    3,556
    Sep 30, 2009
    San Francisco, CA
    even if it only runs the printer for a few mins, a+. we almost DIE when our breaker triped or the power goes out and the printer gets slammed. it resets almost every setting.
    we now have run a dedicated 20amp breaker to our two printers because when we ran the microwave and the printers it kept blowing the breakers! ACK!
  7. cgsigns_jamie
    I'm surprised you don't need a larger circuit for two printers. My one XC draws 13 amps when running.
  8. signage
    signage Major Contributor
    9,662
    113
    63
    Oct 5, 2005
    Penn
    My suggestion is to hook an amp meter up and take reading while your printer is printing with all options working (feeding off roll, pre and post heaters running on high, takeup reel pulling) then take this reading and multiply it by the voltage this will give you your true operating wattage. Now take this wattage and multiply it by 25% and that would be the minimum size UPS I would recommend! Cgsign if you printer is drawing 13 amps and hooked up to a 120VAC outlet you wattage is 1590W so that 1500W UPS is not large enough!
  9. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    I'm using a APC Smart UPS 3000.
    on Roland 300V & 3 PC with dual monitors...
  10. cgsigns_jamie
    Very good advice ... the UPS I linked to was 1980w :thumb:
  11. DGDesigns
    DGDesigns Member
    96
    Excellent feedback from everyone. I was just double checking on what everyone was using because the unit I specd was around $900. Thought that was nuts at first, but can't afford any damage either. Thanks, "signage", on the calculations.
