Thank you guys for all your input. I'm processing it all, thinking back this issue probably did start when I changed out the carriage assembly. I swapped out the assembly with an entirely brand new one.
You asked about the "bearing raceways": Are the bearing raceways the 2 bearing that are at the bottom of the assembly with the springs? If so they were replaced, new one came with the assembly..
Back when I changed the carriage assembly, I found out my original carriage assembly wasn't bad and it actually didn't need replaced. The CR motor was my issue back then.
When you asked about the carriage making noise. I did notice in the last prints I ran a very subtle tick at the end of the pass before the carriage changes direction to go back to the cap.
Possibly I should go back over all the step of the carriage assembly to be sure everything is tight and secure? or maybe even put the old assembly back in?
Were the bearing raceways also replaced when the carriage was done? Vibrations in the carriage movement do cause this issue. The yellow would be almost impossible to see and the black is dark enough to cover the issues.
