Click to Support Signs101 ...
If my dampners are bad on a Roland VP540I will it cause my printer not to print? If I do a power clean and remove my drain bottle there is no ink draining in it.
It could be the dampers, but first of all I would check the cap tops ( putting a syringe on the tubes and pull). its easy to check this way if the tubes are clogged or the rubber at the cap tops don'g close correctly anymore.
