I'm having a very frustrating problem with my normally dependable Mutoh Valuejet 1304. Yesterday I was printing 3 banners, all the same. The first two went fine, 3" into the third the print suddenly changed colors, went from a brownish color to a green tint, just like you drew a line. I had replaced the yellow and magenta carts during the first banner. I did a few cleanings, checked the drain lines and then started printing test blocks of CMYK. Everything looked fine except the magenta. The print quality is great, the only problem is the magenta is way too light. I don't have another magenta cartridge to try, do you suppose it's a bad cart of this color?
Not sure what else to check, any ideas? Thanks!!
