bad test draw
skasigns
I'm desperate. Printing started out ok this morning, then things started looking bad. Did a test pattern and two little spots didn't print in the cyan area. I did a custody wash and it got worse. Most of the cyan area was missing. I called Advantage tech support, but didn't get any help. I got on here and read a few threads. I tried a strong head cleaning, another longer custody wash and fill up tank. It still looks really bad. I'm hoping someone can help me!
Thanks in advance for any suggestions! It's greatly appreciated!!
Kim
HaroldDesign
What machine is it? My first guess would be to clean the head and station by hand with the correct fluid and cloth.
skasigns
Mimaki JV3-130. I've done a custody wash the last three days with the cleaning solution and foam swabs.
thewood
Are you filling the capping stations with cleaning fluid during the Custody Wash? For how long are letting the heads soak?
thewood
Could there be some debris on the underside of the head? After a long nozzle wash, you may want to try gently wiping the underside of the offending head with a swab soaked in cleaning fluid.
Modern Ink
Post a pic of your test draws!
There could be several factors. Cleaning, bad capping station, slider board..........etc.!
speedmedia
I am betting it is a damper or pump. Had this same problem with the same printer and I changed those and we are rolling steady now!
Thanks,
Kurt
skasigns
Here is a picture of my test print. Thanks
Modern Ink
I assume that your machine is 4 color and running 4x2.
Are you running OEM inks or other (ie bulk ink)?
- Clean the clear strip located behind the black drive belt.
- Pull the screens and clean the inside of the capping station.
- TURN MACHINE OFF!! Remove panel at the left of the platten and move printhead down so you can get to the printheads. Inspect them to see if you have any makrs on the heads & clean the sides and back of the printheads (DO NOT touch the bottoms).
Your dampers should be about 1/2 full - even during printing?
Try a few STRONG cleaing cycles.
You can also try a 10 minute NOZZEL WASH with Acetone. Please note it is NOT recommended to do this by Mimaki or I'm sure any of the distributors. However, we have had to do that once or twice. No problems.
I noticed that you are doing CUSTODY WASHES. If you are cleaning on a daily basis you only need to do NOZZEL WASHES for a few minutes.
YOU SHOULD have a cleaning schedule for day, week and month......
Daily Maintenance
a. Clean around printheads
b. Clean around capping station
c. Clean wiper
d. 2 minute nozzle wash
Weekly Maintenance
a. Same as daily
b. Clean & dust machine
c. Complete visual inspection
d. Pull wiper and clean
e. 5 minute nozzle wash
Monthly Maintenance
a. Remove screens, clean caps and screens
b. Check and Oil Y-Bar assembly (use 3-in-1 oil)
c. Inspect printhead carriage belt
This could also be a bad slider board. The big green board just behind the dampers where all the ribbons and cables plug into.
ColesCreations
Hi.
Thanks for your thanks re the battery!
Ive seen this a few times after near empty cartridges with the printer not running cleaning cycles.
We have gotten them all back with strong cleanings; just make sure to only clean head 3 and 4 to not waste too much ink.
