Banner Material "Puckering" up
Discussion in 'Materials' started by duggan, Jun 28, 2012.
  1. duggan
    duggan Member
    35
    I am having a reoccuring problem with banner material. It seems to always want to pucker up and I get head strikes. I have a Roland SC540 printer. Any suggestions on what I could be doing wrong or could do to try to fix this problem? In VersaWorks I am using the print profile for Banner Material.
    I didn't know if it was an issue with it getting to hot, maybe a preheat setting or something like that?
    Thanks for any help!
    Duggan
  2. BigfishDM
    BigfishDM Merchant Member
    5,017
    418
    83
    Jun 22, 2009
    All Over
    Hmmm is it a 13oz? What brand is it?
  3. Wiggum PI
    Wiggum PI Member
    298
    Oct 3, 2011
    Melbourne Australia
    The weight of the rolls is usually the biggest issue, are you letting slack off the roll or is it pulling direct?
  4. edgette
    edgette Member
    154
    1
    I had some issues with my mutoh with banner material when my heater was up to high. I turned it down a little bit and it runs fine on either head height.
  5. DizzyMarkus
    DizzyMarkus Active Member
    822
    I had this issue a few weeks back and it was 13oz from Beacon. Happened a few times, then someone suggested the small spring loaded clips ( http://www.homedepot.com/buy/tools-hardware/hand-tools/2-in-spring-clamp-114693.html) from Home Depot to weight the material as it comes through -- works awsome and havent had a strike since. I do have to baby sit enough material to come out so I can get the clips on.
    My print is 44 and dryer is 40
    Markus
  6. idsignsil
    idsignsil Member
    350
    1
    18
    Oct 30, 2010
    Springfield, IL
    I used to have this problem. What I have figured out it this...
    1: Make sure that the roll has slack on the back at all times
    (This way the machine is not pulling the entire weight of the roll)
    (Downside - You have to look at the printer every few minutes)
    2: Use the media clamps
    3: On the front you need to keep something pulling the banner down so that any wrinkles are pulled out. You have 2 options
    A: Run extra banner material to a take-up reel before starting to print
    so that the banner is pulled tight (this wastes material)
    B: Put clamps on the material for weight until the material reaches the take-up reel
    (Little spring hand clamps with the orange handle and tips... I use 2 on each side)
    I run 13 oz banner with the heat settings and profile from Versaworks. I think it is the generic lightweight banner vinyl profile, but I am at home and not 100% sure. Anyway, this is what I have found works for me.
  7. idsignsil
    idsignsil Member
    350
    1
    18
    Oct 30, 2010
    Springfield, IL
    I was typing while Markus posted. The clips/clamps he suggested are the same ones I was talking about.
  8. CS-SignSupply-TT
    CS-SignSupply-TT Very Active Member
    1,541
    1
    Just had a customer come in with pictures reflecting the same problem. Pre-feed is the most common issue. If you are using 50 meter rolls, the weight of the roll causes feed/wrinkle issues. Therefore, pre-feed/slack in the roll is simplest solution. In the slack, you may want to consider placing an empty banner roll in the valley of the slack
  9. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    +4 pre-slacken the roll -- also, I have my pre-print heat almost at 0 with banner material
  10. john1
    john1 Guest
    Had this issue before, turn down the print heat. Mine for regular vinyl is 112 and banner is 90. The dryer heat on my machine is at 104 for both vinyl and banner material. I don't pre-roll out any material and never get head strikes with the heat setting.
    I use the normal small media clamps.
  11. s7graphics
    s7graphics New Member
    8
    unroll your banner till it gets close to the floor prior to printing. This will allow slack from the roll. When the printer takes up the media and the roll is too heavy, it will pucker up. you can also adjust the head height by reaching in by the print heads. there is a lever to raise it up
