Best core for HDU hanging sign?
Discussion in 'Hand Made Signs' started by Handmadesignmaker, May 16, 2013.
  1. Handmadesignmaker
    Handmadesignmaker New Member
    5
    Does anyone have advice on a 1/4"-1/2" core for an outdoor hanging sign. I want to glue up two pieces of Duna Board HDU with something sandwiched in between to provide strength and rigidity. Must have good cutting properties so that I can band saw and sand a custom shape out of the glued up parts. Must take chromatic primer/paint and hold up outdoors. I've worked with Extira in the past and I like it but I have to drive 2hrs to get it. My supplier carries Scooter Board by Woodcraft and I'm considering that. Any advice is appreciated. I just joined today, glad this forum is here. Thanks!
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    I would create an aluminum or steel inner framework
  3. Handmadesignmaker
    5
    Thanks. I need to be able to cut and sand it in a wood shop. I've seen that PVC sheets are best for this, but I don't want to deal with cutting and sanding pvc.
  4. J Hill Designs
    15,549
    16
  5. Billct2
    Billct2 Major Contributor
    7,461
    642
    113
    Mar 12, 2005
    New England
    Extira? Didn't have good luck with it myself. Wouldn't use scotterboard, no strength and real susceptible to water damage.
    Since you want to use something that will work in a "wood shop" and you apparently know how to seal and finish things well (as Extira requires) I would use MDO.
  6. Handmadesignmaker
    5
    I made letters out of Extira. I primed them with Chromatic high build primer and I painted the letters with 1-Shot lettering enamels. The letters are attached to the side of a bus that drives around everyday. They have been out in the elements for 9 months now, driving around and they've held up great through an extremely wet winter.
  7. Moze
    Moze Precision Sign Services
    2,032
    156
    63
    Feb 27, 2012
    Dallas, TX
    I would say to go to Nine Mile and get an order of Soon Come and a Red Stripe and worry about the sign another day. :smile:
    Welcome to the site.
  8. Handmadesignmaker
    5
    Ahhh! Nine Mile is so good! How do you know Asheville? I guess you lived here or visited. Thanks.
  9. Handmadesignmaker
    5
    Scooter Board
    Thanks Bill. Good to know the scooter board is not an option.
  10. Moze
    2,032
    156
    63
    Feb 27, 2012
    Dallas, TX
    Have some family out that direction. Nine Mile has some great food!
