TyrantDesigner
Art! Hot and fresh.
By the way, if you see a jazz themed painting at an art fair and it's signed H.N.G. it stands for "Hot Nuts Guff"
xxtoni!Please relay this to player since I am on his ignore list.
He, player, posted a snide remark to me with post #29 and then I waited to see him do the same thing that he accused me of with post #35. I want to thank him for waking me up from a fog of wasting time with my antics on this forum and dealing with people like him and others that would like to see me sitting in the Time Out Chair.
And as Bob, who I regard as a Jeopardy genius, says that you should explain yourself in three paragraphs, and I feel that I have done that.
If flatbed printing is anything like roll printing any dust or imperfections can show up as defects in the print.
So the quality of the top coating will probably also play a factor in the choice?
When you mention metal companies doing coatings I wonder if these panels are done in a clean room or out on the smelter floor...
Would it not be worthwhile to just print on a Roland style roll printer and laminate the prints onto the aluminum panel?
Are you framing the aluminum prints in some way? or just printing full bleed to the edge of your material. What is your common thickness of the materials that you have printed on in the past? I've had pretty good success printing UV flatbed on the aluminum composite materials, so far.
I use aluminum panels with a bake on white finish and it is pretty good, but there are defects and small dust particles. I don't think I could do any better, but it is not perfect by any means.
I admit that I am easily distracted by shiny objects and don't have anything relevant to add to this thread but,
Skyhigh's helpful message relay to John made my morning.
carry on
wayne k
guam usa
Do you bake the finish on yourself?
Thanks for the input SignManiac. No framing, they are float mounted onto the wall. They are full bleed to the edge and I believe are about 0.043 thickness.
I have heard great things about the UV flatbeds. I probably will eventually get into that. I ordered a bunch of sublimation supplies as thats what I am interested in trying out first hand. I have over 12 years experience using photoshop and illustrator and I remember ironing on designs onto t shirts when I was a kid and I had a lot of fun doing it. I like creating things myself. My father is a professional artist but I did not inherit his talent. I am a very technical person but I do love creating things myself so at the very least this will be fun for me to get into. I ordered a smaller printer and heat press to get started so I can learn that way, but I definitely plan on ordering an epson 9890 soon as well as an oversized heat press probably from geoknight.
To everyone who has stumbled upon this thread looking for information I will do my best to post what I have learned so far about printing artworks onto aluminum substrates. I have not yet began to actually try anything out, but after much research online, phone calls to substrate suppliers, this is the information that I have received and will pass it along here for anyone who it may help get started printing onto metal.
As for printing on aluminum based substrates, your main options are as such:
1. Sublimation. In order for your heat transfer to be applied to a metal substrate, it needs to be pre coated with a polyester based coating. Your best bet for going in this direction is to look at metal suppliers who offer pre coated enamel based blanks. Since sign blanks are a popular medium, its best hitting up these suppliers. Doing a google search for "metal sign blanks" or "aluminum substrate blanks" should yield you plenty of results to sort through. Your results most likely will vary with each supplier so its probably best to order samples from different suppliers to get an idea. There are also your usual aluminum blanks from unisub, dynasub, dynatrans and many others. Johnsonplastics also carries many aluminum blanks. Its best to give these companies a call to explain what you need done. If doing large pieces of art, a wide format printer should be a consideration such as an epson 9890.
2. UV Flatbed printer. Not recommended for your home based user. Very costly and you're looking at a lot of maintenance. Look to invest at least 6 figures in a uv flatbed solution and make sure you get training beforehand. If deciding this is the direction you want to go, make sure you narrow down the machines you're interested in and look at having samples made so you can test the quality. I have found if you call up online companies, they are willing to share with you the machine they use and more often than not they will brag about its capabilities. Placing an order with these companies is a good way to see first hand what type of quality you can expect. The benefit with using a UV based flatbed printer is that from my understanding, you dont need to have the substrate coated with anything although its usually recommended.
3. Solvent printers and DTG printers. I have read the least on these 2 methods for aluminum printing. Some claim to be able to print directly to metal or class without any sort of pre coating. I do not see anything to support these types of claims and there is not as much information on these 2 as there are for sublimation and uv printers. There are some interesting machines here with the neoflex being the one that got my interest. I dont think I will personally be perusing these options but it does seem like a viable option.
As far as my needs go, my art consists of mostly simple modern art on aluminum panels. A lot of the collections are actually a series of colored panels aligned in certain ways similar to this: http://i.imgur.com/svX4qtn.jpg
I have discovered that metal suppliers can actually coat the aluminum panels, but it remains to be seen how close these panels can come to the colors that we need to be applied, so that is ongoing as I wait on samples. However I have found many local aluminum suppliers so at least I have many options there and I am confident I can find one that will suit my needs. Having the epoxy coating on the panels probably means we can also hand paint the panels to match the designs which is the easy part so long as the paint adheres to the surface.
This is an ongoing venture so the information I posted is just information I have found doing my own research and does not yet come from any personal experience.
I will probably make a new post after I have some experience with this so that it can help others who are searching on the web like I did.
I go on ford super duty forums when I have questions with diesels, I was on the samba when I was trying to sell my doodlebug. We all try to find help when we need it and when we do we try and go to the professionals. And some guy comes on here asking about equipment some of you use and explaining in detail what he plans to do with it. WTF IS WRONG WITH SOME OF YOU? I see more verbal attacks than actual help. I see some going into detail about the stupidest s*** over someones post and you dont know anything about them.
And as far as s*** coming from china wth doesnt come from china these days? Believe me if I just started looking into buying stuff for a little venture we are trekking in and every damn thing we are buying comes from china, you wanna blast me for that
the next time someone comes in here asking for advice try to offer help or STFU AND DO NOT POST
