best tips for disposing of used foil?
Discussion in 'Gerber' started by UltraHIVE, Aug 4, 2009.
  1. UltraHIVE
    UltraHIVE Member
    52
    hey all, ive been going through this process thats kind of insane. i destroy all foil before i trash it, by running it through a shredder. problem is that its very tedious and requires some intense cleaning atferwards. this is after i rewound each foil, found and used ALL available open areas to print with. crazy? yep. wasteful? nope. ive even found a use for that first 6 inches of unused vinyl when starting a new project.
    Question: i wanted to know of a safe way or chemical compound that breaks down the foil, besides lighter fluid and a match (tried that)...
    thx. :rock-n-roll:
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    19
    MEK maybe?
  3. UltraHIVE
    UltraHIVE Member
    52
    MEK is sorta hazardous ;) but thats a good one..
    any company that recycles old foil into new foil?
  4. UltraHIVE
    UltraHIVE Member
    52
    evidence dude, evidence... ;)
  5. Billct2
    Billct2 Major Contributor
    7,596
    685
    113
    Mar 12, 2005
    New England
    :help are you serious?
    Who are you doing work for ..the CIA?
  6. J Hill Designs
    15,549
    19
    what, are you printing DMV registration tags or something?
  7. Tim Aucoin
    Tim Aucoin Very Active Member
    Get a cat and give it to the cat to play with. 1 day = destroyed foil!! Problem solved! :ROFLMAO:
  8. Mike Paul
    Mike Paul Major Contributor
    5,441
    8
    38
    Dec 30, 2003
    NJ
    Yep, thats just plain crazy.
  9. UltraHIVE
    UltraHIVE Member
    52
    a cat would work, but then i gotta feed it.. ;)
    no gov jobs, or dmv... just reproductions.
    what i print is small enough to print within the un-used foil areas. larger projects take up the bulk of the foils surface, so its only right to rewind and conserve. the excess vinyl i use to mask off the edges a frame when i screenprint tshirts.
