Best vinyl to stick to Gatorboard?
Discussion in 'General Signmaking Topics' started by speedmedia, Dec 14, 2010.
  1. speedmedia
    speedmedia Very Active Member
    1,392
    Hey all,
    I have been contracted to do some work for a movie filming locally and have a request from them to do some mock artwork printed and then mounted to gatorboard. I would typically use 3651 or something of the like as that is what I really like to use and we always have. Funny thing is only needs to last a couple of days.
    Any other suggestions?
    Thanks,
    Kurt
  2. Bigdawg
    Bigdawg Just Me
    7,459
    133
    63
    Jun 8, 2005
    Sunny Florida
    You could go with the cheaper 3640 if it's only going to be a few days... but I've seen it shrink up pretty fast under hot lights... I think 3651 is appropriate
  3. jiarby
    jiarby Major Contributor
    4,513
    3651 is fine... I usually run around the perimeter with a roller (Speedpress brand) to put a little extra seal on the edges but not too much or it can crush the gator.
  4. d fleming
    d fleming Very Active Member
    2,794
    232
    63
    Nov 28, 2007
    Middleburg, Florida
    CHeck to make sure they don't need a matte finish.
  5. Gino
    Gino Premium Subscriber
    33,530
    2,408
    113
    Jun 7, 2006
    PA
    Wanna play it safe ?? Paint about a two inch band around the entire perimeter of the gator. When dry, apply your vinyl. It will stick to the paint far better then the unpainted gator.
  6. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    3651 is the perfect choice.
  7. WinGraphics
    WinGraphics Member
    64
    Dec 18, 2007
    riverside ca
    I like Ultra board better
    I switched to Ultra Board. It has a styrene face instead of the paper that Gator has. It also cuts super easy and clean with a razor knife. Glantz and Grimco carry it.
