Best way to brace a Lexan Face
Happyprinter
We are installing new lexan faces on a double sided sign 6'x16' in a high wind area. What is the best way to brace these larger faces so they do not bounce around in the wind and break? We have tried running a few screws thru the lexan around the outside edge and this works most of the time but still a lot of play in the middle.
Milo
The item is called a Ti-Bak Wind Brace. You can obtain from N.Glantz or similar suppliers. Google the name and you can see the image and if it fits your requirements.
Happyprinter
Thanks for all the prompt reply's. Mosh I agree, time to convert to flex face. We are trying to talk them into it but in case they wont, the Ti-Bak's will work.
