For much more bulletproof uptime...... go with a professional workstation.
Dell Precision and HP Z Series are both excellent. They do not include all of the consumer bloatware. The DIY crowd will argue and yes they can build something cheaper with the same specs and they can. But
Dell and HP have a LOT of engineering and testing into insuring cooling, airflow, compatibility, etc are all on spot and you can get a warranty that assures service literally within hours. Can also spec systems with ECC ram, Xeon processors as well which also can contribute to even greater stability.
The latest and greatest can also be a bit faster but realistically even slightly older systems can still be phenomenal. I'm using an older
Dell Precision T7910, dual 8 core Xeon E5 (3.2ghz 16 cores plus 16 hyperthread), 128gb ram, factory water cooled, quad NVME SSD's, Quadro video (fully supports 10bit color mode in Photoshop). This thing is from 2016 and still keeps up just fine. My point being you can spend more up front for much higher end professional grade and get a LOT longer useful life out of a system and much better stability and reliability than consumer grade systems.
