Bevelers....Which one????
All Signs Inc.
I have purchased a laser engraver and now I'm looking for a beveling machine. Can anyone recommend one??? Anything in particular I should be looking for???
Thanks,
All Signs Inc.
Well I've heard of both of these bevelers. They say the Scott is OK but and kinda of a entry level machine. The Q1 is about twice as much money but is the real deal. Just what I've heard.
All Signs Inc.
I just purchased a QE1 from Quality. It should be here next week sometime. I figured better get the good one and not worry about it breaking down.
Thanks for the insite.
CES020
Take your laser about 3/8" out of focus and it'll bevel it for you. Need to crank up the power a little, since the spot size is bigger. It won't give you a 45, but it'll give you about the same as if you were using a profile cutter on the rotary engravers.
CES020
It works well on machines that have a programmable Z. You can change the focus level by color, so it's a piece of cake to do. Just engrave in focus in one color, then assign a different Z height to the vector color and you're done.
V-ENGRAVE
Going that far out of focus would require high power and slow speed and possibly more than one pass.
What I do is pre-cut plates on rotary with desired cutter angle. For this process I have two cutters, one with 38-40 angle and another 45. Doing it this way speeds up jobs cos while laser is marking one batch I can prepare next set of blanks and apply 3M 467 on them. BTW, cuts are not all the way through so blanks stay joined for easy loading/unloading in laser.
jiarby
that's ridiculous
we vector cut the plates with the laser then feed through the beveler. I do not have a rotary or I would probably do it as V-Engrave does.
CES020
that's ridiculous
Why is it ridiculous, because you've not tried it? It works and it works well, otherwise I wouldn't have posted it.
You want to make it 2 operations, fine with me. We'll stick with "one and done".
