PrintItBig
Hi,
We've been looking at flatbeds for a while and are at the point where we need to stop procrastinating and make a decision. Due to various reasons that I won't go in to these are the 2 models available to us.
We want to print all kinds of display related products, Foam PVC, ACM, Acrylic, Banner, Vinyl, Correx, Eflute, Bflute, etc. Some of our stuff is for close viewing and some is not. I just wanted to get some subjective opinions on which one to chose. We realise they're quite different machines and there probably isn't a right or wrong answer, we're just trying to gather as much opinion as possible to help us make a decision.
Jetrix KX6
True flat bed with a roll to roll option
Max sheet size = 2440mm x 1220mm (8ft x 4ft)
Max roll width = 2.2m (86”)
Cheap ink
Permanent white ink
2 year warranty including heads and subsequent years at £6.5K ($10K) per year
Very good quality print
Roughly 2 to 3 times quicker than the HP for similar quality
Roll to roll not as good as HP
HP FB750
Big hybrid
Max sheet size = 2500mm (98.4") x as long as you like
Max roll width = 2.5m (98.4")
Better ink adhesion than Jetrix
White ink involves switching out the Light Cyan and Light Magenta inks - £40 ($40) each way
1 year warranty (no heads) and subsequent years at £10K ($15K) per year
Print quality not as good as the Jetrix
Has to be slowed down to print without banding
Pretty reliable roll to roll
It's a tough one because we're torn between the quality, speed and white ink of the Jetrix vs the unrestricted size and better ink adhesion of the HP.
The Jetrix is about £5K more than the HP but the running costs are lower.
Anyone have an opinion? What would you do?
Thanks.
http://jetrix-usa.com/index.php/PRODUCTS/jetrix-kx6/
http://www8.hp.com/us/en/commercial-printers/scitex-presses/fb750.html#!&pd1=1
Jetrix KX6
Cheap ink
Permanent white ink
HP FB750
Big hybrid
Thanks.
