big job I just finished
Discussion in 'Portfolio Board' started by signguy 55, Nov 15, 2013.
  1. signguy 55
    signguy 55 Member
    293
    1
    Just finished two of these heaters at an asphalt refinery down in Savannah, Ga. Total size of the lettering was 22' x 8'. All painted from a lift, no vinyl used. Used pounced patterns and latex paint.
    Felt good to do this, very satisfying. Not counting the layout, actual painting time was about 5 hours per side.
    Still have to do a water tank, it will be about the same size layout.
  2. JBusch260
    JBusch260 Active Member
    764
    Jan 22, 2013
    HUUUUGE! Nice work! :thumb:
  3. Gino
    Gino Premium Subscriber
    33,490
    2,384
    113
    Jun 7, 2006
    PA
    :thumb:... and nice fade to boot !!
  4. TXFB.INS
    TXFB.INS Very Active Member
    1,209
    30
    48
    Jan 5, 2012
    Lone Star State
    that looks like fun!!!
    what prep did you do to the surface before painting?
  5. visual800
    visual800 Very Active Member
    3,931
    268
    83
    Aug 4, 2010
    montgomery, alabama
    This is the most funnnest work aint it?
  6. Craig Sjoquist
    Craig Sjoquist Major Contributor
    6,746
    4
    38
    Jun 18, 2004
    Orlando
    Good looking job well done.
    With a pattern makes it so easy & fun to finish
  7. Jillbeans
    Jillbeans Major Contributor
    14,457
    19
    38
    Dec 24, 2003
    Butler, PA
    Refreshing to see some painted work! Nice job. It's also SO refreshing to actually be painting it, huh!
    Love....Jill
  8. signguy 55
    signguy 55 Member
    293
    1
    Thanks for all the kind words.
    Yes it was satisfying, the guy that was running the man lift asked me how many guys in this part of the country could do this type of work. I told him maybe enough to count on one hand.
    I told him you just take a big job and break it down into small sections, not only the physical part but also mentally. That's the way it works for me anyway. It keeps you from being overwhelmed. And yes, once you have it laid out it's just following the lines.
    The surface was coated with some type of high temp latex paint, since these were heaters that evidently heat asphalt to several hundred degrees. It was semi rough, I used a fitch for the smaller letters and a 2" brush and 3" roller for everything else.
  9. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    that's massive! great job
