Big squeegee
Gnomic
Hi
Which of the big squeeges should i buy, to get the application tape(ht55, 126cm) on my wall decal (oracal 631, 122cm)? Think its called "masking". Guess is the "Model BSL", from the link below.
I live in europe and the only place which has anything in stock is here:
Tarifs - Laminateur ManuelLaminateur Manuel
Is it s a must to have the "cradle" on the BSL? instead of it being in there and instead its just being pushed forward, is that a bad thing without it?
The Big Squeegee
Long Time Member
The cradle on the 50" length laminator helps to give the tool rigidity. You do not need to mask a print if you install it with the Big Squeegee. You will need to mask areas that are irregular so that the tape will pick up edges. Edges on the trailing side do not need masking.
For lettering, mask with narrower tape and overlap to keep it together.
