Morph1
Print all
Mimaki JV3-160 Sp CMYK x 2 config.
One more question,
My printer just stopped printing black the other day,
I had a bad head test print for black so I soaked the head gave it a good clean and wow, no print at all at test swipe.... ????
What I did is gained access to the pumps at the back, the pump thats pushing magenta and black it working there is no leaks however I am not getting any black sucked out onto the discharge container...,
I thought a Line clog, what I did next was gained access to the black and magenta ink tray under the cover on the left , disconnected the black lines one by one, took the line off the head, took a syrenge and squeezed some cleaner through I seen it coming out on the other side by the head... so I know there is no line leak or either blockage....,
I repeated the same thing through the other black line and same thing,
now the lines are clean no inks in them at all, I connected everything back up ran a clean up cycle and I can see the inks are not being sucked ouf out of the ink cartridges... ???? it must be the pump, but how could that be the pump when it sucks the magenta out no problem????
can anyone help out ???? I don't wanna leave the printer in this state over the holiday ....
any help would be appreciated.
thanks
Drew.
One more question,
thanks
Drew.
