artbot
i need to run black only on my 160sp.
the problem is it works for a small file but when i do a large file it's twitchy.
right now i am using a grayscale file. lots of solid blacks. color correction +25 on black.
it works perfectly on small files (10mb).
but on files around 200mb occasionally it will magically start printing purple-ish gray.
(the black line doesn't have black in it, i am just needing to isolate it as a spot channel. i'd use the two white channels but i don't want to contaminate those lines. black ink is kind hard to contaminate, and white is the worst).
so what am i missing? a little check box somewhere that will force this printer into black only mode.
any help would be much appreciated. this issue is frustrating.
