I can post pictures later but basically I was wondering if one of you guru's had an opinion on the first things to check. I have owned and self maintained this printer for about 4 years now and have never had to replace a part other than regular maintenance stuff (with the exception of the steel head belt breaking once!)
Anyway - Doing a nozzle check on the original head which has printed tens of thousands of square feet shows that all nozzles are firing well. When printing on Matte PSA everything seems fine too. When I print on gloss vinyls the issue becomes noticeable. The black ink seems to print liney in straight horizontal lines almost as if nozzles were out - but they aren't. It's fairly inconsistent and very thin lines close together. I know you really need a picture so I will post one later, but I have never had an issue like this.
Could it be head related even though all nozzles are firing? I think the reason you notice it on gloss and not matte is because gloss simple shows defects easier - I'm sure upon close inspection during print the issue is there on Matte vinyls as well.
Printer history:
OEM inks until about 6 months ago when getting OEM inks became an online only thing around here. (I also purchased two new printers so I was able to justify going non OEM)
I switched back to OEM for a a good month or two along with a thorough cleaning and it didn't fix this black issue.
Printer is about 5 years old.
Print has just about all original parts.
Printer is due for new dampeners and such, so if that could cause the issue it might be the problem.
Original cleaning station.
Believe me I am 100% pro OEM, so please don't start the non OEM ink battles. If you honestly think that is the problem then you can say so, but I don't need any other unrelated comments about it. I HATE non OEM ink but it is the best bet for my situation on this printer.
Thanks in advance. I apologize if I have left out any required info, just ask and I will reply asap! I will try to get pics on here within a couple hours but don't wait on them if you have an opinion on the mean time.
Printer history:
