Blade gone wacky on cutter
Discussion in 'Graphtec' started by Flame, Aug 25, 2006.
  1. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Okay, I have a Graphtec FC7000-100 plotter. I just replaced the blade as my old one was getting dull. I went to cut and noticed that in some parts of the design it was cutting through the paper, and on other parts, it was barely scratching the surface!!! I cannot figure out WTH is wrong with the machine, and several of us have spent most of the day playing with the depth and cutting force, and nothing seems to work. I had this happen once a few months back on another Graphtec of mine, and I found the culprit to be a faulty blade (had a chip in it from the factory). However, I've tried 3 different blades this time, one brand new, one 3 months old, one 1 month old. None of the them work.
    Does ANYONE have any ideas? This is my only plotter I can use for cutting out my prints, and I am in the middle of a bunch of rush jobs and I can't get any of them done with my plotter not cutting properly. Anyone...?
  2. Mike Paul
    Mike Paul Major Contributor
    5,441
    8
    38
    Dec 30, 2003
    NJ
    Sounds like your cutting strip may have lifted a bit in that spot.
  3. javila
    javila Active Member
    843
    If it's always on the same spot check the teflon strip underneath.
  4. Flame
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    It's everywhere across the strip, and the strip is fine. The machine is only 4 months old, so I don't have any parts getting old anywhere (unlike my other Graphtec I have).
  5. Si Allen
    Si Allen Very Active Member
    2,146
    1
    Call Old Paint....he knows that kinda stuff!
  6. Derf
    Derf Very Active Member
    Did you check to see if your spring or that area is gummed up at all? my Graphtec some times gets a tiny bit of vinyl stuck where the blade comes out or adhesive gets in where the spring is and causes the blade to stick way down or up at random
  7. Flame
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    I got it to cut okay...after around 250 test cuts. ouch...
    But to get it cut properly, I had to set my pressure setting at 30, where before it was always at 23 for that vinyl. WTH? It doesn't make perfect sense to me...
    Atleast it's cutting though... not right.... but cutting.
  8. javila
    843
    It's possible the blade is different size(shaft).
  9. madisonsignguy
    madisonsignguy Member
    284
    Yea That's what I was thinking. Are you sure it's the same type of blade? Seems weird that you would be using more force with a new blade. usually just the opposite happens.
  10. Derf
    Did you get the old and new blade mixed up..... LOL
    I've spent some time under a magnifying glass trying to figure out what blade is what!
  11. gerald
    gerald Member
    405
    You probably backed of the manual pressure adjuster when you changed the blade. It's easy to do since it's right there on the blade holder.
  12. TC49010
    TC49010 Active Member
    528
    I had something similar on a cx-24 and I didnt have the holder seated all the way. Same way with the sx-15. I found if its not fully seated you have to extend the needle or increase the pressure.
    :help: just food for thought!!
    Trixie
  13. Pro Image
    Pro Image Major Contributor
    4,550
    Nov 28, 2005
    Flame try and see if you can move the blade in the holder(see if it spins round in the holder) if not the bearing in the holder are rusted up and one of them is locked.................try a littler 3in1 oil that should free it up.......
    I had one do the same thing a little oil and was back good as new............
  14. Flame
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Weird.... I just took everything apart, BACKED OUT the blade depth, and the thing is working like a charm.
    Bizarre... but atleast it's working great again. Don't know what I did differently, but it's cutting like a charm, at the regular pressure, and with the new blade.
    Was I under a 5 hour curse?
  15. Pro Image
    4,550
    Nov 28, 2005
    Damn Flame you had your printer go haywire on you, plotter f'up and some thing else I can't remember happen to you in the past week or so.................
    Who was it that said "KARMA ain't she a *****!"
    just though I would mention that.....
    someone else posted to you about the karma after the stunt you and rhino pulled...........and it seem that it has eatin your *** alive.........:Big Laugh :Big Laugh :Big Laugh
  16. kevco
    kevco Guest
    Was the new blade the type that has the waxy protective "glob" of what ever it is on it? I had one like that one time that just left a little piece of that stuff on it and had the same problem.:help:
  17. javila
    843
    It's grease on the tip. =)
  18. Flame
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Yeah, I had to peel that dumb wax off. Could have been a tiny piece left over on it.
    Uh...Dustin. WTH? Welcome to a print shop. I've had to bust out over 6,000 decals this week, from 2" x 3" to 5' x 5'. Gone through half a set of inks and a plotter blade. I run into glitches all the time. Screw Karma, it doesn't exist. Everyday !@#$ does.:Big Laugh
  19. Pro Image
    4,550
    Nov 28, 2005
    As for welcome to a "print shop" Ive been printin' for a lot longer than you have, can you say FARGO 310 ..........SO SUCK IT UP!!!!!!!!!!!!!!!!!!!!!!! hahahahah
    Just messin with ya a little.............:eek:)
  20. Flame
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Then you know $#@! happens.
    Not karma.
