Blade Pressure for Roland
Steve Prince
What Blade Pressure under Cut Controls for Roland VS540 VersaWorks are you using? Both for 3 mil and thicker 6 mil vinyl.
Lucky Sky
It varies, the thickness of the vinyl, the thickness of the adhesive, and wear on the blade. Just checked it is currently set at 95. I always do a test cut at the beginning of the job, then again mid way through if it is a large job.
Mosh
from 100 to 145. Laminate or not, detailed design, new or old blade...
Pressure changes on mine about every job....on average orcal 3551 with 290 laminate is
135-145 depending on the age of the blade.
