Bleed not holding in Onyx 12
Discussion in 'General Chit-Chat' started by Precision, Jul 28, 2020.
  1. Precision
    Precision New Member
    14
    2
    3
    Aug 26, 2017
    Jurupa Valley, CA
    Today while printing I noticed that ONYX had dropped the bleed settings on my print. The original file was 47" wide x 108" tall. I added an inch bleed to the panel all the way around, which should of made the print 49" x 110".
    While printing I noticed that the bleed line was printing in some areas, but in others was blank. It did not hold the bleed setting? I am confused.
    Is there a setting that I am overlooking, or should check. I truly appreciate your comments and help.
    Thank you,
  2. greysquirrel
    greysquirrel Active Member
    594
    82
    28
    Aug 13, 2015
    West Berlin, NJ
    hard to say...onyx is now on v19...you would need someone running v12 to help
  3. CanuckSigns
    CanuckSigns Very Active Member
    3,433
    398
    83
    Nov 11, 2008
    Ontario
    Onyx has some glitches like this, it will often forget settings like paneling layouts as soon as you click submit. Try rotating the artwork in your design program and resending it, not sure what but sometimes this fixes odd issues in onyx for me.
    When I first started using onyx after using versaworks for 10+ years it seemed really clunky and counter intuitive, but after a while you get used to it and it becomes just clunky...
  4. SignMeUpGraphics
    SignMeUpGraphics Moderator
    1,360
    287
    83
    Apr 11, 2012
    Australia
    Did you have the correct roll width set before print?
    We had this issue on one job last week and turned out the roll width was off by about 5mm so it wasn't printing the full width of the loaded media. Lucky it was just an outline and we could easily trim it by measuring the bleed out with a ruler.
    • Like Like x 1
  5. Grizzly
    Grizzly Member
    184
    19
    18
    Sep 1, 2010
    Utah
    This ↑, as well as try hitting apply after you add the bleed. That can help make sure it doesn't change.
