Blind Sign/Plaque Mounting Hardware
Discussion in 'Product and Supplier Referrals' started by rdm01, May 19, 2020.
  1. rdm01
    rdm01 Very Active Member
    1,011
    Dec 28, 2007
    Portland Metro Area
    Hello,
    I'm hoping to get a recommendation on a product that would allow us to blind mount about a dozen 6" x 6" ACM signs for tenant identification on outdoor units. We would want to be able to switch them out without damaging the exterior of the building. I think they're a little to small for a French cleat style handing system. I was temped to create something with a backing plate that is screwed to the building and then perhaps something like dual lock to mount the actual sign, but thought there might be something a little easier/better that someone knows of.
  2. DustyCanine
    DustyCanine Multimedia Specialist
    45
    5
    8
    Nov 14, 2017
    Atlanta
    Ive been using this company for years. Always easy to work with.
    https://mbs-standoffs.com/
  3. MikePro
    MikePro Major Contributor
    4,909
    215
    63
    Feb 3, 2010
    Racine, WI
    you're gonna damage the building either way: simply tape & silicone to building, or drilling holes for mounting hardware.
    got a pic to work with, or maybe additional details like brick & mortar or aluminum siding or whatnot?
    otherwise, +1 MBS-standoffs for a great reference to the kind of kits/hardware readily available for fancy-mounting interchangeables.
  4. JBurton
    JBurton Signtologist
    1,586
    316
    83
    Sep 28, 2017
    Arkansas
    Agreed, though you need to consider whether these are likely to get stolen/vandalized. They make some with a set screw that cost more. If they are not likely to get messed with, aim for the version with the screw/cap section as on piece, these things add up rapidly when your quote 4 corners x 20 units. Aside from saving money, it'll save you a ton of time in opening itty bitty baggies for each and every component...
  5. rdm01
    1,011
    Dec 28, 2007
    Portland Metro Area
    The quick snap from MBS is perfect. Thank you!!
    And I should have clarified, I don't mind "disturbing" the mounting surface, but would want to be able to change it without say, ripping off a ton of VHB and silicone. This system allows me to ship the client a replacement that they can pop off/on. Thank you again.
