Bondo Alumalite Edges?
kirkbedtelyon
Anybody ever fill the edges of an Alumalite corogated sheet with bondo then sand flush and paint?
Anybody ever epoxy edge cap moldings onto the sides of Alumalite?
I'm looking for alternative edge treatments for an Alumalite wall mount sign (no frame). I've had problems with the 3/8' edge caps changing shape / popping off from 10mm panels.
Thanks.
Eric H
Bondo is a bad idea I can't imagine it would stick too well, use one of the solid core materials and save yourself the time and grief.
kirkbedtelyon
The sign is 5' x 8'. I'm not finding an aluminum skin or vinyl skin solid core product that's at least 3/8" thick and 5' x 8'.
Suggestions?
Billct2
We have some aluminum edge cap that works on alumalite.
More often if we don't want to see the coro core we use Phenoseal paintable caulk, but usually just use black and leave it.
Never heard of doing any of the things you mentioned. Basically because they don't make sense.
This thread is a little like another thread here going on about Cor-X not lasting long.
If you people are selling the wrong substrate for the job, why are you looking for methods or ways of polishing a turd ??
If you want aluminum to not have an edge, then use REAL aluminum. Now, you have a choice to bend it over and create a nice return or just buy the substrate thick enough so you don't need to do anything other than paint it.
Alumalite and all the other composite aluminums are a cheap way out of buying aluminum sheets. Wanna make something cheap look good, try giving the customer all the choices and let them decide not to go with the expensive thicker aluminum sheets and then you don't have to worry about aesthetics of lesser grade items.
Edna
Can't you use 4.40 alumnium and bend a lip on your brake to make it
look 3/8 thick. This is how my man does race car bodys. Then yo could
glue stifofoam on the back to make it ridgid.
WOW, my 100th blue post, you are one lucky man!
kirkbedtelyon
Thanks Gino, Don't get yer pantys in a bunch...This sign is for an airplane hanger. Nothing fancy. Just looking for an inexpensive way to make the edge of panel look a little cleaner. And I found it.
Jillbeans
I think Bondo would pop right out if the sign bowed when you were delivering or installing it.
Love....Jill
