Hi Biker Scout,
I'd agree with everything, with exception of tangential-cutting, which I spent the over a decade believing superior to drag-cutting. But a after a year of working closely with Graphtec / Graphtec OEM cutters, I had to change my opinion on that. Graphtec cutters, head-up, really do out-perform Summa T cutters, in pure cutting ability. But in tracking, Summa is still slightly ahead, I believe.
I think the explantion is that Tangential's strength is also its downfall. Lifting the blade from the vinyl is both good and bad. Bad, because it can cause "ears" that you simply don't get with Graphtec, especially on tiny stuff and thick materials (supposedly, T's main advantage).
I also think that corner cutting, on finer details, benefits when the blade doesn't leave the vinyl surface ... dimensional changes, on the microscopic level, can occur in the time the blade lifts from and returns to the vinyl surface. Plus, Graphtec's soft landing accomplishes much that T does, with way less movement.
I'm sure you'll agree that T is slow when cutting Tangentially. So throughput is WAY faster on Graphtec, and in the end, the cutting is better too.
But on really long stuff, and especially in contour-cutting automation, Summa is, I believe still, superior. But I must admit, after years of believing (and debating) otherwise, that Graphtec has surpassed Tangential with its drag-blade technology.
IMHO,
Jim
