Bronco II Template
signgirl71
I think I may have asked about this before, but I have to get this done next week. Does anyone have or know where I could purchase a vehicle outline for an older Bronco II. I think it's an '88. I would rather not use the photo because I have to do 8 inch trim around the bottom and wheel wells. The wheels wells are what I need the most and since I am so anal I want it just perfect. Any help would be appreciated!
signgirl71
Thanks much but hubby says that is a full size so it's not what we need. Guess the wheel wells aren't the same.
Sparky
here is the easiest way to do it right -
- Grab some 1 inch masking/transfer tape and grab your digital camera.
- Place 3 or 4 strips of tape, both horizontal and vertical, at each end of the wheel well and one or two in between.
- Stand back from the wheel well as far as you can and zoom into the are with your camera (standard zoom, not digital zoom) and click - you have a picture you can scale.
- Open the photo in photoshop and scale until the pieces of tape are the right width for your scale.
- Use that photo as your base of your new template.
Has worked perfect for me several times, and it very easy to do. Just make sure that all of the widths of the tape are equal.
Good luck!
signgirl71
Thanks - guess I'm going to have to try that. No templates seem to be available. Hopefully all goes well!
