Butyl Carbitol
Discussion in 'Mimaki' started by Artgunner, Jun 28, 2011.
  1. Artgunner
    Artgunner Member
    141
    Feb 7, 2008
    Concord
    ArtBot, I saw your post in another thread about Butyl Carbitol and if I understand correctly, this is the same chemical used as cleaner for Mimaki printers/ solvent inks?
    If so I found some at Sherwin Williams’s chemical division store for 25.00 a gallon.
    Art
  2. CS-SignSupply
    CS-SignSupply Very Active Member
  3. MikePro
    MikePro Major Contributor
    4,974
    235
    63
    Feb 3, 2010
    Racine, WI
    carbitol is just an extra ingredient in a good homemade mix of cleaning solution for the JV3. artbot's posted a good recipe that also includes mostly butyl celusolve and acetone, with the carbitol being a slight addition.
    I get all my ingredients from a local chemist, but Sherwin Williams should carry it all too.
  4. Artgunner
    Artgunner Member
    141
    Feb 7, 2008
    Concord
    Here is the post...
    mix butyl carbitol 5 parts with one part acetone for a homemade cleaning solution.
  5. Artgunner
    Artgunner Member
    141
    Feb 7, 2008
    Concord
    This stuff works great! I fine that adding a little more Acetone cuts the dried ink better. Have jets firing a fine line of fluid now on all 8 jets. Did it all while in printer. Also... changed cap at docking station. :toasting:
