Click to Support Signs101 ...
Make sure you use a UV protective lacquer though! home printer inkjet inks aren't UV stable and can fade very quickly if the model is displayed in daylight.
Usually not.. Just cut them out roughly.. Its basically just the ink attached to the lacquer film with a water based glue underneath. Very fragile. But fine once on the model and protected by lacquer
