Can I changes these thing I hate about my Roland Printer/Plotter?
Discussion in 'Roland' started by Andy D, Jun 25, 2020.
  1. Andy D
    Andy D Very Active Member
    2,338
    442
    83
    Oct 20, 2014
    Hattiesburg, MS
    I "inherited" a Roland VS-540 & it won't do basic stuff I took for granted on other printers, but
    I'm wondering if there's a way to add them, such as:
    - When I'm printing or plotting, especially long contour cuts, I like to jog the material out to
    make sure it's running straight or to make sure the contour marks are lining up, but the Roland
    only has one "jog" speed, creeping. Is there a way to change that?
    - When I'm not sure I have enough material left to print a job, I like to run it out on the
    printer or plotter and have it tell me how long it is. Is there a way to get my Roland to do that?
    - When I run out material and back it up, if I have it on the take-up, it will take it up but doesn't
    roll it back out when I back it up.
    - Is there a way to have the plotter recognize a different type alignment marks for contour cutting?
    I'm sure I will think of more... any help will be greatly appreciated.
  2. artxaoc
    artxaoc New Member
    2
    Jun 29, 2016
    RussiA
    1.You can't
    2. Menu>sheet remain>set length. after that on main screen you will see changes
    3. You need original take up system like this https://www.rolanddga.com/technologies/take-up-systems (It will take it up only after "setup sheet" mesurement and spring is lowered)
    4. No, it does not. But you can make cropmarks by your self at corel or illustrator. Just draw the same like this printer do. https://st6.ning.com/topology/rest/1.0/file/get/2811840427?profile=original this is for older version printers. At VSi some changes.
    • Informative Informative x 1
  3. Andy D
    2,338
    442
    83
    Oct 20, 2014
    Hattiesburg, MS
    So you tell the printer how much material is left or the printer tell you how much material is left?
    Edited to say: Thank you for #4, that will make my life so much easier!
    I got it set up and wii try it soon.
  4. Andy D
    2,338
    442
    83
    Oct 20, 2014
    Hattiesburg, MS
    Are you really in Russia?
  5. SignMeUpGraphics
    SignMeUpGraphics Moderator
    1,360
    287
    83
    Apr 11, 2012
    Australia
    You need to tell the printer how much media is on the roll first, then it will calculate usage and when you unload you can get an update from the machine. This is easiest when starting with a fresh roll.
    You'll also need to update this each time you change a roll. You can get the machine to "PRINT MEMO" which will print stats onto the media just before you unload it so you can pop those numbers back in next time you load it up.
    It's not fully automated, but better than guessing.
  6. artxaoc
    artxaoc New Member
    2
    Jun 29, 2016
    RussiA
    Of cource, at first you need to insert value how much is left of roll media. Its good for new rol. But when you are use allready used roll you can insert any value(much bigger of real length) for accuracy of measurment at any cases =) Usualy it's need for unpacked different types of media rolls. Canvas, vinyl, baner etc... Print the memo and you allways will know material balance. After couple years of work with sign graphics - this is unused function =) You will determine the remaind of material by eye.
    And yes. I'm in Russia.
