Can I load a 100mts roll to Mimaki JV300
Xavier Elizondo
Hello guys,
I need to know if I can load a 100mts (328ft) length Backlit roll to my Mimaki JV300? The total weight of the roll is 37kgs (81.5 lbs)
The local distributor of Mimaki told us that it's not possible. But I checked the specifications of the plotter and it says that the maximum weight of the roll should be 40kgs (88lbs). So according to this data, it should be possible to load the roll.
Has someone tried it before?
Thanks in advance
slopoke
I'd be more worried about the roll being to wide and sitting on the support bar under the roll. I'm running a JV33 and can't load a 150' roll of 18oz banner without having to peel some off onto another core because it's too big around and sits on the bar. Just a thought.
Xavier Elizondo
Thanks for the answer. But I think JV33 has less capacity for loading materiales (25kgs vs 40kgs for JV300). Moreover the 18oz banner is more dense than backlite film.
Someone with an JV300 who has experienced difficulties to load big rolls?
Your material is within the weight spec but the diameter of the roll might be the only problem. What Slopoke is saying is that it may be too wide to roll without hitting the support bar. Measure the diameter of the roll and have your dealer measure between an empty core to the support bar. That should get you the answer you need.
