Can I print to the edge of vinyl
Phil Swanson
I am doing a job that I don't want to see a white outline around the print. In my past experience when I print to the edge of the contour cut, the vinyl wants to curl up as it dries. Is there any way to stop this?
I am using an SP300 with standard solvent inks on Orical 3651 vinyl. Should I be using a different vinyl?
ironchef
You gotta wait overnight or longer, and then lamimate. If you dont have a laminator invest in a big squeegee. If you cant wait, you gotta still wait overnight atleast before you cut.
