Kemble
I have a Mutoh ValueJet 1204 (48")
I'm using 30" material and I want to print 30" wide. Yet when I set the artwork up to 30" and make sure the panel is 30" I'm still getting 3mm of white space on the left and right edges. By going through the menu options on the Printer itself there is a setting for Side Margin and it's set to 3mm yet 3mm is the lowest setting. Is there a way to bypass this so I can print a full 30"?
