Cannot open port / MUTOH VJ 1204
Grafix USA
I had to reinstall a hard drive in my system and reinstall Flexi. The Graphtec cutter works fine and everything tests fine on my printer, but when I send a job to Production Manager, after the ripping is done, the status says "Cannot open port".
I did a search and tried chaning my IP address to 10.1.10.25 and it didn't help.
I have alway used the following setting with no issues:
IP 172.018.003.101
Subnet: 255.255.255.000
Gateway: 192.168.001.254
Port: 9100
Any suggestion on what I can do to get this working? The only change was that I had to reinstall Flexi. I am connected to the printer with a network cable and the cutter with USB, but that is the way I have always had them connected.
Thanks!
(I'm going to post this under software as well since I'm not sure where the issue is.)
thmooch
just throwing this out there...firewall or virus software settings ? Did you have to reinstall or was the drive a secondary?
Grafix USA
I'm running AVG and I had to reinstall all my programs. I'll try to turn it off and see if that makes a difference. I'm not sure how to tell AVG to open a specific port, but I'll have a look. Thanks for the idea.
thmooch
I think Mutoh has a "test" software download that will send directly to the printer(well they do for my falcon), that bypasses RIP software. Might want to look into that. to see if you can narrow it down.
OlsonSigns601
I have a VJ1204 too.
We run a it on a PC that has Flexi, Windows XP and two network cards. One for Flexi and the network card on the Motherboard uses the LAN/Internet.
I have what you are talking about happen to me at least twice a year. Generally when we take the PC out to be cleaned. Somehow we always have a problem when we disconnect the cords and plug them back in.
What I do is this:
Step 1: Disable Both Network Cards.
Step 2: Reboot
Step 3: Reenable one Network Card
Step 4: Configure that network card to work with Flexi
Step 5: Verify it works, then reenable the other card which should then automatically work with the internet.
If you need any help disabling or enabling the network cards, let me know.
thewvsignguy
line #22 in the above post:
"On the printer go to Menu > Setup > Set23 IP Address. Change the IP address of the printer to 10.1.10.253. Go into Production Manager and change the IP address for the printer to 10.1.10.253. Restart the printer and you should be good to go"
