Need Help Cannot read OPOS marks on glitter vinyl.
Goatshaver
Sorry for all the threads. I don't have anywhere else to ask for real-world knowledge.
I'm printing on RTape metallic vinyl and have OPOS marks for cutting. I did the media calibration since this is very difficult to read. I was able to cut one sheet a couple of days ago, but I'm trying and it reads 2 of the marks and fails on one.
Is there a way to be able to cut these without reading the marks? I've got about 10 sheets of this I need to cut and it's driving me mad. :help
wildside
I have also had luck by turning the lights off. Sounds weird but the reflection from the light in the glitter causes unpredictable results. Shutting the lights off is not fool proof, but 8 out of 10 works.
Raum Divarco
General Manager CUTWORX USA / Amcad & Graphics
The room lighting and contrast settings can be useful. You may even consider placing some soft lighting above the machine. You can also try to knock down the reflection around the dot with ink. you could have a larger circle with a lower % of yellow for instance to washout the reflection and read as you usually would. Using edge detection and incremental offsets is also an option but can be troublesome.
Goatshaver
It's already in a pretty dimly lit corner. I managed to get one sheet to read but another wouldn't. Guess I gotta run the gauntlet in trying everything I can. Thanks
Goatshaver
Good idea since I'm setting these up in Illustrator anyways. Thanks!
gabagoo
what do the registration marks look like? Mine makes 3mm squares which I can cut in matte black and place over the exisiting and sometimes that works... I also have used a pencil eraser to dull the marks which seems to help the reader
same issue with many vinyls, colored/reflective/exotic finishes.... i just place a frame of tape around the perimeter and redraw the registration marks by-hand with a fine tip sharpie or a black ballpoint pen.
Tizz
I have taped around the printed squares using white vinyl, just small strips. The light still bounces off around the printed squares. This is enough to trick the camera.
Goatshaver
Same marks. I just used some transfer tape and redrew them in worked like a charm.
DrunknMonk
have you tried the trick with yellow translucent vinyl ? I tried it, it was better, but still a pain
RICHARD SIMMONS
What I do is cutting little squares in black flat vinil, the same size of the printed, place them over the printed ones, and there you go !!
pkeshtgani
I have tried all those suggestions above but none of them ever work for me. what I did instead was to make 1" squares with white vinyl with the middle cut out the size of the black squares, than place it over the existing squares. That way there is a big block of white around all the marks.
jerry369
I read and appreciated the various attempts to be able to overcome what are the limits of the optical sensor on particular materials, for examples reflective, (also if no one has yet mentioned the use of hairspray to dull the material) but there is one, and only one, solution if you often work on these materials and it is to use an S Class 2 TC version, the one equipped with OPOS Cam.
Time and material saved over time will pay off the investment made to buy it
Goatshaver
I did some red metal flake and it couldn't even calibrate that media because it's dark and the marks are hard to see. I've gotten good results by placing some application tape over the mark and cutting the square out and then reading it. It's kind of a pain but it works.
Signed Out
I wish there was a setting (maybe there is?) to print a flood of white before laying down registration marks. A nice block of white underneath would surely solve this problem. I've run into it from time to time on reflective. Of course you need white ink capabilities for this to work. Anybody know if this is possible with an epson s80 running on onyx thrive 19?
