Need Help Canon imagePROGRAF PRO-4000s w/ PERF703036A HELP!
Discussion in 'General Signmaking Topics' started by alexbaumgarten, Sep 11, 2018.
  1. alexbaumgarten
    alexbaumgarten New Member
    4
    May 10, 2017
    Effingham
    Having alot of problems with this material. Even after a few days of drying the ink is easily removed by the tape to put these on windows. Using the adhesive vinyl setting on the printing and through Indesign. Please help! Photo attached. IMG_20180910_151746.jpg
  2. fuzzy_cam
    fuzzy_cam The Granbury Wrap & Sign Guy
    164
    35
    28
    Mar 7, 2017
    Granbury, TX
    I still will never understand why people don't laminate window perf.
  3. rm5690
    rm5690 Member
    120
    14
    18
    Jun 27, 2018
    Virginia, USA
    I have the ipf9400 and have had issues with ink coming off of synthetic substrate as well. (In my case it was a polypropylene psa). I spoke with my manufacturer and they actually made a custom media profile for me so that the printer wouldn't lay down as much ink. It doesn't produce the colors as accurately as I'd like, but at least it doesn't rub off. Maybe try talking to your manufacturer or vendor?
    There are 9 different "Special" media types pre-built in my printer interface - not sure if its the same for you - but the profiles are actually a spectrum of how much ink the printer will use. I just forget if #1 uses the least ink or the most. I would try a strip test and print on Special 1 and and Special 9 (if you have them).
    Try Canon's IPF tech support hotline 800-423-2366
    Word of advice InDesign is great for layout but not the best for printing from, especially if you're using a custom media profile. I would rip a pdf and print from Acrobat. Make sure you chose "Let printer manage colors" from the color management section.
    • Like Like x 1
