Can't import .EPS into Corel Draw Essentials
Discussion in 'Corel' started by thurstonracing, Jun 20, 2008.
  1. thurstonracing
    thurstonracing New Member
    11
    Dec 11, 2007
    I can't seem to get these .EPS and .PS files to import into Corel Draw Essentials which includes a stripped version on Corel Draw 9. I have had luck with several other .EPS files before but all I get with these 2 is a blank white screen or a Grey box with the file name and extension.
    If anyone can get these open in Corel could they save them as a .CDR so that I could open them in Corel 9?
    USDA Farm Service Agency Website
    Need this File "FSA_bluebox_cmyk.eps"
    http://askfsa.custhelp.com/cgi-bin/...nNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1
    Also need this one from the Natural Resources Conservation Website
    Need this file "NRCScolor.eps"
    http://www.nrcs.usda.gov/about/logo/
    Let me know if i'm doing something wrong here?
    Thanks, Rob
  2. Pro Image
    Pro Image Major Contributor
    4,550
    Nov 28, 2005
    Howdee from VA.............
    More than likley the files you are trying to import are not supported by version 9......They have been made in a new version of Illustrator or Photoshop.....
  3. thurstonracing
    11
    Dec 11, 2007
    Thanks for the response!
    If i upgrade to the latest version of corel would that maybe do the trick?
    I would rather not have to do that but may not have a choice.
    I did update my corel 9 with whatever updates where available from Corel but that did not fix it either.
    Rob
  4. WhiskeyDreamer
    WhiskeyDreamer Professional Snow Ninja
    3,550
    80
    48
    Aug 6, 2007
    Riften
    i was able to import the nrcs file....i can save it for you and send it via email...just pm your addy
  5. thurstonracing
    11
    Dec 11, 2007
    Thanks for the help! it worked on my end!
    If anyone has any luck on the FSA logo I would appreciate the help.
    Rob
  6. Goatboy
    Goatboy Member
    87
    PM me I have it
  7. thurstonracing
    11
    Dec 11, 2007
    Thank you everyone for all your help!
    You guys are very helpful!
    Rob
  8. Alan D
    Alan D Member
    37
    May 8, 2008
    I suspect you may be using the wrong import filter. The eps filter will only display a low res header (used for the likes of Quark) for positioning and sizing only and will only print correctly to a postscript device. For editable eps use the 'postscript interpreted' filter, this will give an editable graphic (assuming compatible) This was changed in X3 and X4 to help avoide this confusion. Essentials was acut down version I believe so not all filters may be included.
    Just for your info I tried the 'bluebox' file in X4 and it came in fine.
    Alan D
  9. thurstonracing
    11
    Dec 11, 2007
    Thanks for the info. I tried that filter but it keeps telling me there was an error with the file. It might be time to upgrade my corel soon!
