Click to Support Signs101 ...
When i disway and nozzlewash (or try to) the black cap station wont hold the fluid. it will just empty out without the pump working. the other 3 caps work fine. anyone ever experience this?
Most likely cause is pump failure. Not a total failure, but it no longer 'pinches' the tube closed when in the 'nozzle wash mode'.
New pump will fix this. If you replace one pump, you may want to go ahead and replace the other.
