Capping station won't hold fluid (JV33)
Rooster
It's happened once before and sorted itself out, but I'd like to nip it in the bud. For all the times I've replaced print heads and dampers I've never had to deal with a capping station issue.
It should be something simple (hopefully), but I'm hoping you guys can help me out with where to start to address the problem.
artbot
do you mean for a head soak? the capping station is usually plugged by nothing more than trapped air below when you pour some solution into it. if the pump stops in a open position it will allow the ink do simply drain into the waste bottle. from what i know, pumps stop in the closed position. there's probably someone here that can refute or verify that. not sure. or if there is an air leak at the pump lines or the pump is old and doesn't completely seal at the closed position then it will let the weight of the ink press the air out and your head soak will sink into the cap tubes. that's about all i know about. it's all a bit new to me too.
i've got ball valves and inlets hanging out the back of my printer. when i want a head soak to really stay. i have my gf go behind the printer and turn the valve when all the air is bled out of the line, thus leaving nothing but solution. i'm about to install some rc three way fuel valves. they will work much better for the whole retrofit. attached is the current set up. this mod took about 15 minutes to do and i constantly use it to purge, draw ink, monitor pump function, seal off lines, clean lines, diagnose vacuum issues. it is a must have.
Rooster
Yes head soak/nozzle wash. Every time I add fluid it just drains out.
Update: Must have been an airlock. Tried again after another job and it's holding fluid fine. Sponges are nice and clean looking now too.
happened to me as well a few times... But only on the cyan. I just pressed down on the cap a few times with my swabs and it did the trick
