Car Wash Decal Material???
Discussion in 'Labels and Decals' started by LMC, Jan 31, 2013.
  1. LMC
    LMC Member
    41
    Mar 13, 2012
    St. Paul, MN
    I have had a request for decals that will be used inside a car wash.
    They will be out of the way from any direct pressure from the water.
    Does anyone have any suggestions on what may work?
    Thank you!
    Lisa
  2. BigfishDM
    BigfishDM Merchant Member
    5,019
    418
    83
    Jun 22, 2009
    All Over
    180C or any other cast vinyl and lam combo will probably be just fine.
  3. CanuckSigns
    CanuckSigns Very Active Member
    3,396
    391
    83
    Nov 11, 2008
    Ontario
    I'll go one step further and suggest that any laminated vinyl should work, Calendered material should work fine for this application as well.
  4. LMC
    LMC Member
    41
    Mar 13, 2012
    St. Paul, MN
    The humidity won't have an effect on the adhesive or the lam?
  5. JoySigns
    JoySigns Member
    426
    2
    18
    Jan 21, 2004
    Lincoln ne
    The bigger question might be what type of surface are they to be applied to? Lots of car washes are concrete block.
  6. LMC
    LMC Member
    41
    Mar 13, 2012
    St. Paul, MN
    Good point.
    Thanks for the replies!
