heyskull
Well after fitting yet another maintenance station into our 1604 the test print is showing no blocked nozzles and prints as good as the day it was installed.
It is now Seven and Half Years since I had a new print head installed and firmly believe that if blocked nozzles are attended to when they happen you can get unbelieveable life out of a printhead.
The main issue is the carriage bearings are failing and have began to sound rather noisy and the head height has to be constantly set high.
Has anyone replaced the bearings as I have found a chinese supplier and they are for peanuts to buy?
SC
SC
