Cast print vinyl vs cast white cut vinyl
Larry L
Does cast print vinyl, white, last as long not laminated as cast cut vinyl? I have assumed when out of the one, just use the other for cutting only. I was concerned the printed type may have less UV protection for it to accept ink better. I have in the past used the printed types when needed.
Larry L
I noticed the the printed vinyl a bit softer and harder to weed, but have never tested it for durability.
