n20capri
The scaling area must be set to 400% in order for it to actually cut at 100%. Every since I got it this has been the issue but when set to 400% it works fine so I rolled with it. Cutting from Illustrator with the Cut Master plug-in.
However, lately been trying to figure out print cut and noticed when I select "Use Registration" marks it re-scales everything back down to 100% which in reality is only 25%. Since everything is off it will not cut. It also won't let me scale up when using reg marks.
Just did a test - rescaled the artwork to 25% - printed but cut using the correct size art and don't you know it worked because everything lined up since it was all at "25%".
Problem is, I can't play these games of working with 2 docs, re-aligning reg marks etc etc every time...anyone have this issue or know how to fix it?
Much appreciated.
Mike
Much appreciated.
Mike
