Cement Truck Decal help, not sure what material to use
kheebl
Member
I have a customer who wants to redo the logos on some of there cement trucks. The logo is a simple print job but I don't know what material to use. It will be going on the drum approx 42"x33". My main concern is the Lam, these truck do get sprayed with a truck wash once in awhile, so no acid anymore (switched to some environmental friendly cleaner). Also I would need to have a wholesale printer print these up for me, I don't have a printer yet and usually use sign team inc.
T
TonyC
Guest
Tip..
I would use 3M-IJ180 with a matching lam of preferred gloss level.
The most important thing to do is use an edge sealer to protect the edges from those pressure washers.
kheebl
Member
Thanks for that link I just replied to that thread. I tried searching before this thread and couldn't find anything.
jfiscus
Rap Master
We have put standard 3M 180c with 8519 lam and also 3M 680 (reflective) with 8519 laminate on hundreds of these w/o any troubles. by the time the decals need replacing the customers are repainting the drums.
kheebl
Member
Do you edge seal or don't even worry about it?
jfiscus
Rap Master
yes, we DO use 3M edge seal (in the can) on the drum.
for install on the drum, you have to turn it on REAL slow and squeegee quick!
