CET FK512x - Bi-Directional Alignment Jumping Around
MrNick86
I am having issues keeping my print heads aligned on my CET. Some of the heads will jump as far as 7 points offset after a couple 4x8 foot sheets that were printed immediately after an alignment. I could do alignment after alignment and have changes average 1-4 points consecutively. :banghead:
One observation I concurred was the stability of the head temperatures, they seem very unstable. I try my best to make sure doors in the shop are kept shut, the room temp is maintained 68-70F.
I plan on calling CET but I was more curious if anyone else around here has ever struggled with such issues.
Thanks sign dudes :thumb:.
Matt-Tastic
Dumb question first: Are your heads seated tightly? Or could the alignment brackets loose in any way? It's a long shot, but if the physical head is moving, that would explain the issue.
Depending on media, random inaccurate dot placement could be static, or a bad head board, or issues with an encoder. if they are changing in between alignment prints (even if you don't change the values), I would think either something environmental or something electrical; especially if it is inconsistent.
MrNick86
This issue has led to be a glitch in the software. This glitch is so bad that at some point the voltage settings will clear without me knowing. I was color matching the other day and dropped 5% yellow out of a color swatch and the printer decided to go whack and printed an extremely dark color. I rebooted the computer and loaded up the voltage settings and all the voltages were cleared and left with "-" hash marks and C2 at 19.4 volts, which was most likely not all that great for the print head. I really do not know what to think of this glitch. it sounds like there is no software updates with this printer because it is not 'obsolete", says CET. I just wish it was less spontaneous.
davecich
Mr nick,
The issue I believe is the headboard is beginning to fail. Please have James call me, and we can work out a solution.
Dave Cich
MrNick86
I have tried contacting a CET technician about getting this headboard issue resolved. I have not been given any response about it. With that I have been searching for the best tips in calibrating the voltage settings between heads to balance the coverage and avoid banding. I also need some information on things to prepare the printer for a 5 mile move, things to strap into place, any precautions to take to ensure a safe transit.
Any help would be greatly appreciated.
Nameci
@Nick,
I am just a skype away.
You can search my username romel.ginandoy, and I will try to help you out with your concerns.
Best.
