All,
CET Color asking customers to switch to a new ink called Mosaic. I have had an opportunity to do comparisons now. Don't do it.
The ink is not as good as the 50/60/96 series you are running, you will need new profiles, and will probably need to adjust temp and voltage (depends on head). They want you to switch so they can charge you more, and lock you in.
Feel free to call us we have all the ink series in stock as you are using, no change needed, and it will not void your warranty. Plus we will save you 40%.
If you are still thinking about It, make them print PMS 185C, 300C, 512C, 165c, 102c, 287c and send to you. You can see then. It's not worth the headache to spend more for less.
Dave
Dave
