CET White Ink Issues
Discussion in 'Flatbed Printers' started by signheremd, Oct 13, 2020.
  1. signheremd
    signheremd New Member
    9
    3
    3
    May 3, 2016
    x
    Need Help. We replaced our original white Ink head several months ago as we lost many nozzles and it was banding badly. New head printed well at first, but then suddenly only the middle half printed during test prints. Now we have nothing printing and ink does not come out when priming. We have tried using flush to recover, but are not seeing any progress. We had been printing white patches each day to keep it in use. Ink is all new. Machine is not used on weekends. 500 series inks and ricoh heads. Appreciate any advice
  2. Christian @ 2CT Media
    Christian @ 2CT Media Major Contributor
    4,624
    717
    113
    Jun 15, 2009
    Mesa, Arizona
    Sounds like an air issue. There might be air getting in to your head.
    • Like Like x 1
    • Agree Agree x 1
  3. jeffdpia
    jeffdpia Member
    38
    6
    8
    Oct 8, 2015
    Dulles, va
    Sounds like air in the line, bleed the line until it streams without air burping out of the line. Refer to the manual, this should be done for all colors periodically.
    • Like Like x 1
  4. Case
    Case Member
    378
    7
    18
    Jul 21, 2004
    IN
    99% alcohol.... Soak the bottom of those white heads with the lint free wipes........ I have same ink, heads, machine.... Have done it a bunch of times and I get the heads firing again........ The alcohol works better then the flush solution......
    Case
    • Pure Genius! Pure Genius! x 1
  5. Bruce Mello
    Bruce Mello Many years in the Production Business
    86
    15
    8
    Sep 11, 2018
    Long Island, NY
    Case has a good solution.
    Was a bad batch of white coming from Asia this crazy year.
    Another way to try to resolve before replacing is flush by finding a cap you can place under the head so the jets are underwater in a small amount of alcohol and instead of pushing flush through you can attempt to pull alcohol into your syringe.
    Bruce
